No Spark
Old Aug 30, 2009 | 05:21 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
No Spark
My cousin just bought an 89 iroc z TPI the engine turns over but its not getting a spark. Where should I start? dizzy and coil? If it was the VATS it wouldn't even turn over right?
Old Sep 1, 2009 | 01:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
SPARKS IN THE DARK
Right.
In 99% of those cases I replace the ignition module and coil.
Makes for a quick pit-stop.
But if you’re on a budget you need do it step by step to save $$$$$$.
So the first thing to do is disconnect the 4 pin distributor connector, crank the engine while monitoring for spark.
If you then have spark replace the pickup coil.
If no spark while cranking the engine with the 4 pin connector disconnected report back.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
