fuel pump relay?????
Old Aug 30, 2009 | 08:32 PM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
Axle/Gears: 10bolt/4:10
i have an 88 tbi camaro there are two relays near the brake booster........ one is oval one is rectangle, can anyone tell me which one is fuel pump??
Old Aug 30, 2009 | 11:57 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: fuel pump relay?????
shape doesn't matter - size matters - ask anyone.
The relay that has the very large black wire with orange stripe is the fan relay, the other one will be fuel pump.
Old Sep 1, 2009 | 09:41 AM
nzo's Avatar
nzo
Also, the wire you are looking for is Tan/Blk. That is your pump power.
Old Sep 1, 2009 | 09:45 AM
Raato's Avatar
Car: 88 IROC
I picked one up last night for my 88 and here is the AC delco #14089936 hope that helps.
Old Sep 2, 2009 | 11:40 AM
camaro391z's Avatar
Car: 1987 iroc
Engine: 391 stroker
Transmission: th350
thanks guys i appreciate the help, turned out it was the three wire plug that runs to the sending unit..... finaly got it runnin!!!! had a vats issue to but i was able to bypass it and everything works... thank you
Glowsock
Jul 24, 2025 03:15 PM
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Kaweh
Aug 9, 2015 02:54 PM
