Fog lights
Old Aug 31, 2009 | 10:38 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
Fog lights
The first time i pressed my fog light button owning this car at night my gauge lights wiring was damaged and it has since ceased to function. I checked the fuse spot and the circuit is closed. test lighted the button and there was no closed circuit. I checked under the hood as far as i could, my bulbs where fine the fog lights had no closed circuit and the front side lights bulbs where fine and they had no closed circuit either. My headlights are in this wire harness to and they work just fine and have a closed circuit. Idk if this has anything to do with it either but i found this under my hood:
a wire was cut or ripped and the circuit is not closed.
Old Sep 1, 2009 | 01:38 AM
sheltonw3's Avatar
Car: 91' TRANS AM Modified
Engine: Classified
Transmission: Auto with Overdrive
Re: Fog lights
that wire is for testing your A/C and Heat module!....you may want to follow the wiring from the fog lights back to the relay,that might be burned out?
Old Sep 1, 2009 | 07:49 AM
Re: Fog lights
Ok great thanks i didnt know there was a relay i guess ill try and follow it again i kinda lose track of it where it goes into the fender/body
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
