MSD 6AL gets hot and dies
Old Sep 5, 2009 | 06:15 PM
seiplentz's Avatar
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
My car keeps dieing it I think I have it down to the msd causing it. It runs fine for about 15-20 min and then just shuts off, after a few min it will start again and run for 5-10 min and die again. I noticed while looking at it the MSD was very hot so I took a surface temp reading and it was 121 degrees.
after it dropped to 115 the car started and when the temp went up to 126 it died.
What could cause my MSD to get hot like this? bad coil maybe, its an accel supercoil. I did just change the fuse holder at the battery during a cleanup same size wire though with a 20amp fuse though msd claims it doesnt need one I always believe in a fuse at the source.
My MSD is about 6 years old now but not much run time weekend car.
Old Sep 5, 2009 | 08:06 PM
Redrabbit57's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Transmission: automatic
Re: MSD 6AL gets hot and dies
just went thru that with mine after changing cap, rotor, plugs, and wires..........the coil was split open, arcing all over the place..........changed the coil, no more problem..........good luck
Hotrodboba400
Dec 10, 2019 07:07 PM
sreZ28
Oct 22, 2015 08:21 AM
86CamaroDan
Sep 29, 2015 10:08 PM
RedLeader289
Sep 23, 2015 06:50 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
