dome light
Old Sep 7, 2009 | 02:03 AM
mnwildpunk's Avatar
Car: 87 Camaro sport coupe
Engine: 2.8L its so cute!!!
Transmission: Automatic
Axle/Gears: ???
dome light
I searched around a little in the forum but didn't find my answer. Here is my problem, I have a dome light that stays on all the time. At first i thought it was one of the door triggers had gone bad but alas it wasn't. Like I said the light is on all the time but when i press the door trigger in I get a small flicker in the light like the circuit is being interrupted or trying to work. I don't think it is the dimmer switch either because it seems to operate fine as I dim the lights.
Old Sep 8, 2009 | 11:15 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
DOMICILE
The “dimmer switch” (rheostat) is not in that circuit.
However on the same assembly there is a SPST contact that might not be opening.
You can disconnect it to verify.
You might have one of the dome light ground leads with rubbed-thru insulation allowing it to contact ground.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
383cam
Sep 9, 2015 06:01 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
