LQ4 stand alone wiring harness
Old Sep 13, 2009 | 11:47 AM
ironcladwelding's Avatar
Car: 87 tran am gta
Engine: lq4 swap in works
Transmission: t56
Help! I have a 1987 Trans Am with a 6 litre LQ4 motor with a stand alone wiring harness. Can anyone help me hook fuel pump relay from '87 Trans Am so it'll work?? I can get fuel pump to pump fuel only by hot wiring it. Doesn't work through the relay. Can I use the stock relay or is there an after market relay and pressure switch that I can use to shut off fuel pump? I have one wire coming out of the OBD II that says fuel enable. Where would I hook that up??? I'm clueless. Any info would be appreciated!! Joe
Old Sep 25, 2009 | 04:03 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: LQ4 stand alone wiring harness
Welcome!
not trying to pass the buck, but you'd probably get a better answer to this one over in the LTx/LSx engine swap section of the forum.
Old Sep 25, 2009 | 04:53 PM
Stephen's Avatar
Car: 87 GTA
Your fuel pump relay shouldn't have anything to do with the wiring harness itself. All the relay really needs is key on/off power.
IIRC, I don't think the wiring for it, is even in the engine compartment at right, so I dunno why yours would have stopped working.
Old Sep 26, 2009 | 06:30 AM
Car: 87 tran am gta
Transmission: t56
thanks for the info got fuel pump relay to work still don't know what red wire is for comeing from harness
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
