View Poll Results: Fusible Link or Not ?!
Run the new 4 AWG directly from battery to starter!
50.00%
You need to get an fusible link for the new cable...
16.67%
You can replace the fusible link with a AGU (large fuse)
33.33%
Voters: 6. You may not vote on this poll
New Power Cable (battery->Starter)
Old Sep 14, 2009 | 05:20 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
Hi!
Today I bought an 4 AWG (21mm) RED wire to change my positive (+) from battery to starter (main power)
My question is, is it just fine to remove the old one and replace it with this.
Or is there any "fusible link" built-in in these stock wires ?
I didnt see any large bulb (fuselink) or anything on the pos (+) wire from battery
I only checked the battery side of the cabel, will rise the car on wednesday.
But IF there are an "fuseible link" on the main power line, Can I replace it with an regular AGU (large fuse) instead ? Cause We cant buy fusiblelinks in sweden..
Or isnt it needed ? Just run a clean 4 AWG (+) wire from battery to starter ? and im good ?
I will also change the alternator cable and the main NEG (-) from battery to block/head just to have new large good cables and new connectors when I replace the battery..
So the question is mainly about "fusible link" if there is on or if I need one..
Old Sep 15, 2009 | 12:07 AM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: New Power Cable (battery->Starter)
i know 4 gauge is stock, but i went with 2 gauge when i replaced my battery cables. i would've gone with 0 gauge but the biggest they had was 2 gauge. i'm glad i went bigger...i noticed the difference
Old Sep 15, 2009 | 02:00 AM
Theking's Avatar
Car: 1989 IROC-Z
Hmm.. Hopefully my new 4 AWG would work.. I cant change it in the store now, they have cut it already to 1.5 meter and I cant buy another one casue they arent cheap at all..
I saw the poll, so I dont have to worrie about fusible links etc.
My friends (they have 2 1989 IROCs to) They have a large "bulb" on the (+) cable from battery, that must be fusible link, I dont have it and I have the stock cables to..
But there isnt a need for some fuse or fusible link on the main power then ?
Cause they want to change the powercables to but didnt want to touch it until we was sure no fuse/link was needed at the main power (+)
Thanks!
Old Sep 15, 2009 | 05:37 AM
Theking's Avatar
Car: 1989 IROC-Z
Ok I bought new cables today ($45)
For one red 2 AWG (1.5meter) for battery -> Starter
and one black 2 AWG (1meter) for battery -> block/head
Cable is DLS 2 AWG (OFC 99,99% Pure Copper, Heavy Isolated)
So the cable is hopefully a really good one
I also have brand new cable heat socks (HIGH temp protection)
So With these new cables, and protection, they will last forever I hope
I will change the wires tomorrow, some pictures will be taken and posted.
Ill let you know how it turns out...
Old Sep 17, 2009 | 01:31 PM
Theking's Avatar
Car: 1989 IROC-Z
Installation Info:
DLS 2 AWG (33mm2) 99,99% Pure Copper.
Large connectors, will be soldered and crimped to:
Ground Cable Done:
Main (+) Cable Done:
Heatsock for cables etc. Can resist 1100 Deg F, So now the main power cables will be heat protected to:
Old Sep 17, 2009 | 01:32 PM
Theking's Avatar
Car: 1989 IROC-Z
MAX Pictures Reaced...
Made an hole to get the ground one in to:
Starter Side (heat protected starter and cables) :
Good protection against moisture etc, rubber seal and crimphose and larger wire then stock (10mm):
Battery Terminals, All Done
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
