I'm so lost...electrical guru's please help!!!
Old Sep 15, 2009 | 07:06 PM
transamchic87's Avatar
Car: 1987 Pontiac Trans Am
Engine: 5.7/350
My car is an 87 Trans am, with a 350, TPI....I have a couple questions...first, what is this thing, where does it go and what does it do?? I'm so lost...electrical guru's please help!!!-dscn2493.jpg
2) I can't seem to find the connector for my MAT sensor, is it common for some ppl to not hook it up? Am I gonna run into serious issues if I don't hook it up?
Old Sep 15, 2009 | 08:53 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: I'm so lost...electrical guru's please help!!!
The picture seems to show the oil pressure sender that's supposed to sit on top of the block, in the very far back, driver side. It plumbs into the oil passages and gives you a reading on the dash.
The MAT/IAT sensor uses a two-wire connector, tan wire and black wire. If it's not under the back of the upper intake manifold, check the back of the block, it sometimes falls off.
Hope this helps.
Lou
Ranbo108
Sep 9, 2015 12:20 PM
formula_novice
Aug 18, 2015 08:48 PM
confucius101
Apr 18, 2003 05:36 PM
Streetiron85
Mar 11, 2003 08:26 PM
KILLDOZER
Oct 31, 2002 08:05 AM
