1985 Trans Am 5.7 broke down
Old Sep 17, 2009 | 03:06 PM
rdsxfn524's Avatar
I was driving my 1985 Trans Am that we just bought while driving, to see if the a/c was working I went to turn the air on and the car shut down giving me no power brakes or steering. We pulled to the side of the road and tried to jump it didnt work. The windows wouldnt go up or anything. After a while we found a small black tube hanging below the car and when you play with it the car gets power and you can start it. Does anybody know what this part is.
http://tinypic.com/r/xdim1u/3
Old Sep 17, 2009 | 05:26 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
Re: 1985 Trans Am 5.7 broke down
That looks like the heat shield tube for the starter wires. It sounds like you have a loose ground or the tube is banging against the + terminal on the starter and shorting out or blew a fuse.
Old Sep 17, 2009 | 09:20 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
definitely check for loose wires on the starter...
stalkier
Dec 6, 2015 11:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 31, 2015 04:52 PM
stalkier
Aug 21, 2015 01:54 AM
Dquickshift
Aug 12, 2015 06:21 PM
