Calibrate temp gauge/sender?
Old Sep 22, 2009 | 10:16 AM
Crazymidget01's Avatar
I installed a gauge cluster that I purchased off of ebay into my 1985 Camaro 2.8L. I believe it was a z28 cluster with the dual speedometer needle with mph and kph opposite each other. Anyway all the gauges worked except the coolant temp and oil pressure. I started by fixing a broken ground on the cluster, and then installing a new temperature sending unit. The gauge now works, but when I reach operating temperature it reads in the red, and I know my engine is not overheating. Is there a different resistance that I can compensate for in the cluster to calibrate the gauge to read properly. I plan on changing the oil pressure sending unit soon also...hopefully I won't have this problem with that. Thanks for any help...
Joe
Old Sep 22, 2009 | 02:01 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Page 4 Gage
You didn’t state if it’s accurate on the cold end of the scale.
That could change the answer.
Anyway you can put a resistor in series with the gage.
Use a 2KΩ rheostat and put the **** in the center.
Get your water temp up to 160°.
Adjust the rheostat to read 160°.
You can disconnect your fan to Get your water temp up to 240°.
See if your gage reads 240°.
Compare the readings to a test instrument gage to make sure your newly calibrated gage is giving you reliable info.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime or if there is a little rain!
Old Sep 22, 2009 | 05:08 PM
Re: Calibrate temp gauge/sender?
I'm actually not sure if the cold end is accurate, what is the easiest way of testing the actual water temperature?
Old Sep 23, 2009 | 10:56 AM
NINÅ's Avatar
Transmission: 765R4
Gage Rage
Immerse the sender (except the electrical connections) in a vessel of water maintained at 100° monitored VIA a known good thermometer.
Now you can calibrate the low end of the gage.
Happy Racing!
Old Oct 8, 2009 | 06:50 PM
Mike M's Avatar
Using a Rheostat or even a resistor in line with the sender will only let the gauge read accurately at one temperature once it is calibrated properly. The gauge is "calibrated" for use with the sender used on the vehicle from which it came and THAT is your fix. Contrary to popular belief the gauge CANNOT be recalibrated. It is designed to work within a specific resistance range which corresponds to the proper temps.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
