4 pin distributor wiring
Car: 1984 GMC. soon to be 1986 camaro
Engine: Carb'd 350
Transmission: TH 350
Axle/Gears: Stock
ok I just got the engine pulled from my truck and there was a 4 pin connector. does it have to be plugged into anything or is all i need a hot wire to my coil?
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 4 pin distributor wiring
it will run with just the hot wire connected,but the
timing will be fixed at wherever the timing is set-
there will be no advance,that is controlled by the ECM,
or on many early-80s pickups,by a spark control module through the 4 pin connector
Engine: Carb'd 350
Axle/Gears: Stock
so can i leave it unhooked and everything run ok? or should i get a module and hook up to it?
Car: '82 z28
Engine: L83 5.7
might run halfway decent with no spark advance,but
will be down on power,especially at higher rpm.
you could also swap out the electronic distributor for an
earlier one with mechanical advance and vacume canister (pre-81 cars and pickups,many pickups through
'86 also had non-computer distributor,these will have
the cone shaped vacume advance canister)
Engine: Carb'd 350
Axle/Gears: Stock
I think that I have figured out what to do after searching around some. I can take the green and black wires from the plug and cross them and then retard the timing some and that should work
eightsixseven
Dec 16, 2024 01:50 PM
