tach on pause with headlights on
Old Oct 7, 2009 | 07:24 PM
dvardaman85's Avatar
Car: 1985 Chevy Camaro
Axle/Gears: 3.08
First off, i just was wondering if everybody on here feels like their car just slaps them in the face about once a week?
anyway... when i turn on my headlights and dashlights the tach just freaks out like its spring loaded for a sec then stops at any given rpm. as well as the oil pressure guage reads ZERO which pretty much sucks.
But here is the good part so get ready!!! if you dim the dash lights all the way down till they turn off ......... the tach unfreezes and the oil pressure reads right again. however it is really hard to see them without the dash lights on you know???
Old Oct 8, 2009 | 01:07 PM
Axle/Gears: 3.08
Re: tach on pause with headlights on
so i guess that means nobody else has had this problem? ha! well at least its origional... are there any after market guages that basicaly bolt in?
Old Oct 8, 2009 | 01:33 PM
Raato's Avatar
Car: 88 IROC
I had a similar problem and the copper threads on the back of the cluster had a break. I found the break and soldered it and it works fine now. If you cant find the break, I was considering jumpering the ground from the good side of the cluster to the bad side but found the break (next to the pass side turn signal socket) so this wasn't needed. good luck.
Old Oct 8, 2009 | 06:17 PM
rybread11's Avatar
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
My gages act funny, similar to yours. What it is, is the gauge cluter is loose, I changed to a z28 cluster in my berlinetta, and havnt fineshed putting the faceplate and everything back together, and Ive only got it held in with a couple of bolts. try pushing on the cluster and holding it in tight, (to make sure it is conecting to the electrical plugs in the back) and then do the things that make the gages act funny and see if it stops. probly want to pull the black plastic face place off and then push on the housing of the gauges, or you could try pushings on the clear plastic infront of the faces of the gages themselfs. When you are turning your lights 0n/off, it may be just the right movement to be causing the connections in the back of the cluster to have a bad conection. Or the connections may be dirty some how and need to be cleaned and youll have to pull out the gauge cluster and clean the connections. Please ignor the miss spellings
Old Oct 10, 2009 | 10:21 AM
Axle/Gears: 3.08
tried seating the guages by hand while turning on the lights but didnt work.
tried looking for breaks in any of the wires but i couldnt find any anywhere.
where exactly is the ground on the tach and how do i maove it?
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
Eric-86sc
Sep 28, 2015 11:37 AM
