HELP!
Old Oct 9, 2009 | 09:02 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
HELP!
i have no clue what is goin on. i changed the altenator and that battery and something is still draining my battery even when the car is off. the alternator is not charging the battery at all and im lost on what to do. any suggestions? thanks Ty.
Old Oct 13, 2009 | 12:02 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Alternative Solution
Did you change the alternator because you knew it was bad or were you just guessing that was the problem?
Old Oct 15, 2009 | 05:56 PM
rickys69charger's Avatar
Car: 1985 chevy camaro
Engine: V8 305 5.0
Re: HELP!
take out the bulb in your trunk and under the hood. also maybe the ones that light up the passenger and driver side floor. There's a good chance one of those are staying on 24-7
