Fuel pump questions
Old Oct 12, 2009 | 09:23 AM
russ89gta's Avatar
Car: 1989 pontiac trans am gta
Engine: tpi 5.7
Transmission: th700r4
Fuel pump questions
Forgive me if this should have been posted somewhere else. I recently replaced the engine in my car. While the engine was out I replaced the fuel pump. When I got everything back together, the fuel pump would not come on when I turned the switch. I have taken the pump back out to check the wiring harness I installed, and it appears to match the instructions. I also replaced the fuel pump relay, but that did not help. My mechanic told me that I should hear some kind of 'click' from the relay when I turn the switch, but nothing happens when I do, but the motor will turn over.
What suggestions do any of you have for what could be causing the problem? Does anyone have a picture of an assembled fuel sending unit so that I can make sure that I wired mine up correctly? Would any other relays under the hood cause the problem? Thanks for your help. By the way, the car is an '89 Trans Am GTA.
Old Oct 12, 2009 | 09:26 AM
Z2887's Avatar
Re: Fuel pump questions
It is possible that the new relay you bought is bad. Wouldnt be the first one I've seen anyway.
Old Oct 13, 2009 | 09:31 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Don’t Be Fuelish
It might be difficult to hear the relay *click* from inside the car.
Have a friend turn the key to the RUN position while you listen for the *click*.
You can find out if the fuel pump itself works VIA applying 12 volts to pin E of the pump relay.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Oct 13, 2009 | 11:16 AM
russ89gta's Avatar
Engine: tpi 5.7
Thanks for the replies! One more question....How do I know which pin is which?
Old Oct 13, 2009 | 11:45 AM
NINÅ's Avatar
Transmission: 765R4
Don’t Be Fuelish
Pin E is the GREY wire.
Happy Racing!
Old Oct 13, 2009 | 12:06 PM
russ89gta's Avatar
Engine: tpi 5.7
Re: Don’t Be Fuelish
thanks alot! I'll try it when I get home today
Russell
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
