Need Help SunPro Gauge set up
Old Oct 21, 2009 | 02:45 PM
88FFCdunkel's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 305 TBI
Transmission: t-5
Axle/Gears: 3.11 no/posi
Where are the locations to hook up a mechanical temp gauge and a mechinical oil pressure gauge..
And also does anyone know a good location on the firewall to run the hoses? on an 88 firebird formula 305 TBI
Old Oct 21, 2009 | 03:46 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Sun Shine
The locations are the same as the electronic ones.
The oil sensor sender is located in the lower left side of the engine.
It also gives the run signal to turn on the fuel pump so you’ll have to circumvent it if you haven’t done so.
The location of the water temperature sensor varies depending on type of engine however it’s on the left.
You can probably route the tubes thru one of the grommets used for the wiring harness.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Oct 22, 2009 | 10:50 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Sun Shine
if you're not looking to remove any of the current sensors in the engine bay, there are a couple of other spots available.
temp - since you mentioned you have a tbi setup, you can use the spot in the driver side head for this probe. You may need an adapter depending on what came with your gauges, but it can be found at any local auto part store for $1-2
oil- i tapped off a spot right near the distributor.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
colton_carlson
Mar 8, 2019 12:21 PM
ChevyZ71
Aug 13, 2015 07:30 AM
