coolant temp sensor
Old Oct 21, 2009 | 05:47 PM
StringRust's Avatar
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
coolant temp sensor
I have an 87 z28 305 4bbl. What is the sensor on the driver side thats in the block under the manifolds? Is that one of the temp sensors? And if it's bad is that what would throw the "low temp indicated" code and make the car idle higher? I know the CTS will make the car run rich if it thinks the engine is cold. The people at napa keep trying to give me an o2 sensor, they seem to be all confused about what the code means and the sensor that may be bad.
Old Oct 21, 2009 | 06:01 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: coolant temp sensor
My coolant temp switch is on the passenger side (305TBI) and the O2 sensor is on the drivers side....I know different engine but>> When I wasn't certain at first, I just ganked it out and brought it in..... FYI >>> If it is your coolant sensor don't have your head directly under it when you pull out like I did
Old Oct 21, 2009 | 06:15 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
On the driverside of the head between cyl 1 and 3. 1 green wire going to it.
If that is the one you are reffering to it is a temp sensor and it is for the gauge only.
Old Oct 21, 2009 | 06:40 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
yep thats for the guage. and the cts for the ecm is in the intake manifold.
Old Oct 22, 2009 | 09:01 AM
StringRust's Avatar
The one thats in the intake man. is that the one on the thermo housing and the one that would throw that code?
Old Oct 22, 2009 | 01:24 PM
Engine: 383 hsr
yeah, and on the thermo housing? idk if its ON the thermo housing (mine aint) but yeah thats the one
Old Oct 22, 2009 | 03:42 PM
StringRust's Avatar
yea I have a sensor directly on top of the housing.
Old Oct 24, 2009 | 01:57 PM
Engine: 383 hsr
alrighty lol. swap it out
Old Oct 27, 2009 | 11:50 AM
StringRust's Avatar
anyone know the right part number for it. I took it out and brought it to the store but nobody seems to know how to match it up.
Old Oct 27, 2009 | 03:14 PM
Should be this one.
http://www.autozone.com/autozone/cat...xt=temp+switch
Old Oct 27, 2009 | 08:14 PM
StringRust's Avatar
Thanks. Looks like it, don't know why they can't match it. dummies.
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
L98GTA87
Oct 19, 2015 10:43 PM
corey8084
Sep 17, 2015 02:56 PM
m00n420
Sep 11, 2015 02:39 PM
