anyone know about elec door locks??
Car: 1985 Z28
Engine: 305ci 4barrel
Transmission: 5-speed
85 Z28.......electric door locks just quit working, when i push either switch (LH or RH door) neither lock moves at all, but i do hear a "clicking" sound coming from somewhere under the dash in the steering wheel area. is there a relay or something down there. what would cause both locks to quit? anyone had any experience with this? thanks, rick
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Locked Thread
Yes there is a relay in that car.
You have a short which is making the protective device too hot.
Use an ammeter in line with suspected wires to find which one leads to the excessive current draw.
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsFog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Car: 1985 Z28
Re: anyone know about elec door locks??
well, that could be the clicking that i am hearing.....last night i was checking in the fuse box, and one of the big metal 30a fuses (circuit breaker i think) was VERY HOT, i mean too hot to touch. i pulled it out. do circuit breakers get hot when they fail? rick
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Your door locks on that 85 should go through the 30 amp courtesy (or convenience) fuse in the panel and not a breaker. They're powered off the always hot circuit that also powers your courtesy lights, key buzzer and remote hatch release (if you've got one).
Clicking under the dash when pushing the button isn't a normal result of failure of that circuit but could be the result of voltage loss to another circuit when that one is energized. That and the hot fuse(s) would have me checking voltage drop and inspecting my ignition switch and it's wiring under the hush panel.
83 Crossfire TA
Sep 8, 2015 12:06 PM
84 TA NV
Sep 6, 2015 08:02 PM
