battery in trunk, how did you distribute your power?
Old Nov 1, 2009 | 10:35 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Im in the process of redoing everything under my hood including taking the engine out and redoing all of my wiring. Right now i have my power wire coming from the trunk to a 3/8" stud http://cgi.ebay.com/ebaymotors/Red-P...item518db8e1f4 and i have all the hot power wires for relays and interior lights, and my starter all on that stud. gets the job done and ive had it for almost 6 months but i dont like it how can i make it look proffesional??
help me out, i would like to see some ideas or how you did it. thanks in advance
Old Nov 1, 2009 | 10:55 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Re: battery in trunk, how did you distribute your power?
You could use a distribution box from a 4th gen. It has 2 post and a cover to hide the post.
Old Nov 2, 2009 | 01:05 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
82-2002 Camaro Firebird BMR Battery Relocation Kit
http://www.hawksthirdgenparts.com/82...cationkit.aspx
Goes right in place of the spare tire. I know it's not what you're asking for, but could possibly help keeping the battery in there :/
Old Nov 2, 2009 | 07:21 AM
i already have the battery in a battery box in the spare tire location but i just wanted to redo the wires. wanted to make it a cleaner setup.
Old Nov 3, 2009 | 07:58 AM
any ideas??
Old Nov 4, 2009 | 10:18 PM
would you guys run the wire from the cutoff switch to the starter, then have all the hot wires go to the starter???
colton_carlson
Mar 8, 2019 12:21 PM
Brcharrelson
Aug 26, 2015 07:47 PM
pimprs
Aug 24, 2015 11:20 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Firebird sweden
Aug 16, 2015 05:02 PM
