Anyone know how to install the wiper lever on the steering wheel?
Old Nov 4, 2009 | 10:32 AM
Hooyah's Avatar
I recently have changed the steering column and have this new issue with the lever that makes the wipers function. anyone know how to replace it? if so bring on the knowledge.
Old Nov 8, 2009 | 08:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Anyone know how to install the wiper lever on the steering wheel?
Grab firmly in one hand - and Pull it.
If it has cruise control than you will need to carefully snake the cruise wire thru the column to get it out.
Old Nov 10, 2009 | 09:20 PM
4bblackbird's Avatar
How do you snake the new one on? Mine has thoughtfully snipped wires so the handle can come off easier in my discovery process..
Old Nov 11, 2009 | 06:49 AM
Zwrench's Avatar
Car: 1987 IROC (parts car) '86 IROC
Engine: 5.7, None
Transmission: 700R4, None
The connector at the bottom of the cruise wires is flat and has a small hole drilled in it. Attach a small wire through that hole and pull the cruise wires back through the column so that you also pull the wire you attached into the column as well. Use the wire to pull your new cruise harness back through the column. If you have tilt-wheel, make sure the column is straight.
You can expect this set up to get caught inside the column about a half dozen times so don't pull too hard, just keep re-trying.
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
