89 IROC won't start... not a bad starter or battery
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Yesterday (9/9) my car worked fine. Today it won't start. Push the clutch in, turn the key, nothing. The starter doesn't turn over. Voltage drop is minimal, from 11.8 down to 11.1 when I turn the key from run to start. It's almost like power is not being directed to the starter. Battery is good, starter should be good. I checked the engine fuse and it's good. The security light does not come on, and I've tried both primary and spare keys, so it doesn't seem to be a VATS issue. Any suggestions?
Thanks,
Justin
Thanks,
Justin
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Guest
Posts: n/a
Re: 89 IROC won't start... not a bad starter or battery
I had an issue like this with my pos 89....they kept telling me its behind the clutch pedal....I never did find it. Youll have to search here for it and use a volt tester when you find it.....someone who knows better will chime in......
power comes from the battery to the ignition, to the switch, then out to the starter and what not....
Car: 89 IROC-Z28
Engine: LS1 "ASA"
I came across a thread that talked about the switch, or what turned out to be switch(es). Like I mentioned before, I have never had a problem with these, so I don't know where to begin. I read about a Clutch Safety Switch and a Neutral Safety Switch. According to the names, my problem would lie in the Clutch Safety Switch. I don't know. THe biggest thing is if someone could tell me where the location of both switches are and how to test them with a voltmeter. I'm guessing to test the voltage AFTER the switch to see if the switch is letting the power go through it?
Car: 89 IROC-Z28
Engine: LS1 "ASA"
Don't need it ASAP, but I'm the kind of guy that if there's a problem, I want it fixed immediately, and I do not like having the car towed and worked on at a shop due to all the extra fees and labor costs. It is my daily driver so having it fixed soon is a plus, but I do have a backup if needed.
Alright, so I have to test the clutch safety switch, which according to a repair manual, it is located on the clutch pedal assembly by the steering column, I'm gonna check the wiring going to the starter.
Anybody else with other suggestions on things that could have gone wrong?
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Copy Transmission 10-4
The clutch switch is located behind the hinge part of the clutch pedal.
Visually tracing the harness that goes to it will help.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
Guest
Posts: n/a
db057
Aug 11, 2015 10:11 PM
mustangman65_79
Aug 11, 2015 03:17 PM
