no brights
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: no brights
high beam switch needs adjusted - it's under the steering column above the brake pedal - get a small flashlight, a 7mm nut driver, and get upside down head first in the floor well and as you pull the lever you'll see the moving rod and the switch - adjust the switch so the rod pushes the button on the switch.
Re: no brights
Thanks nice day today I will go try that
Car: 1992 Camaro RS 25th An.
Transmission: 5 Speed/ Stock
Axle/Gears: Stock
Re: no brights
SO did it work?
i have the same problem on my 92 RS as well.
is it really that simple as to tighten a screw?
dbrochard
Sep 25, 2015 04:56 PM
louishenry
Aug 28, 2015 09:41 AM
