92 wont start sometimes A/T
Old Nov 11, 2009 | 01:06 PM
dope show's Avatar
Car: 92 camaro rs t-tops
Engine: 3.1 v6
ok so the problem is sometimes it wont start i turn the key on i can hear the fule pump then turn the key to start and nothing happens. it got me stuck in the rain for 2 hours last night trying to get it to start tried everything checked all the fuses, pulled the place off around the shifter and checked the plugs there, pulled it in nutral tried to start it shoved it pack in park and tried again even tried every gear and nothing, so then got under the hood and crossed the started with the key on and it just turned over and no start. after sitting in the car wet and freezing for another 30 min i hit the key and it started up. its happened about 4 times before, it seems to happen after the key has been turned back for awile.
my starter is fine and my battery is good
has anyone had this problem? any advice for a fix?
thanks
Old Nov 11, 2009 | 02:44 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Car Is Not Cranky - Now I Am
Your problem is consistent with poor/dirty connections at the starter.
Remove all wires, with sandpaper make all the terminals look as clean as they did in 1992.
Reassemble and cover the deal with marine protectant.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 11, 2009 | 04:03 PM
dope show's Avatar
Engine: 3.1 v6
Re: Car Is Not Cranky - Now I Am
i cleaned that all up last year when i repaired the starter. when i crossed the starter and it turned over the security light came on but it wasnt on when i first had the probem.
Old Nov 15, 2009 | 06:25 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Re: 92 wont start sometimes A/T
Sounds like you have a problem with the VATS system. I had the same problem with my iroc a long time ago. Everything would turn on but when you turn the key to crank and start, nothing would happen. Then I would wait for a perioid of time, it would then crank and start. I just bypassed my VATS system, but it is usually caused with the contacts in the ignition cylinder for the resistor pellet on the key.
Old Nov 16, 2009 | 09:05 AM
dope show's Avatar
Engine: 3.1 v6
is there a way to fix it without bypassing it? i dont wanna get stuck in the rain again but i'd rather not bypass it lol.
thanks..
Old Nov 17, 2009 | 11:03 PM
schroff's Avatar
Car: 1990 firebird
Engine: V6
Axle/Gears: rear axel has some 9 bolt pattern
sorry just to barge in on your post with my problems but i have the same problem with my 1990 firebird and there is this little key hanging from my underdash by an orange wire what is that and could it be the problem
Old Nov 18, 2009 | 12:39 AM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
This is a link to a thread that has fixed 4 or 5 cars ALL with different No start problems, read it over and give it a try....tons of great info here:
https://www.thirdgen.org/forums/tech...art-story.html
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
