fuel pump
Old Nov 14, 2009 | 07:53 PM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
Transmission: auto 4spd
fuel pump
How can I wire up an external electric fuel pump for my 3.1 V 6 ????? The fuel pump in the tank quit and don't want to drop the tank if I can get out of it.
Old Nov 14, 2009 | 11:45 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Re: fuel pump
I don't think you can successfully pull through your stock pump. We just did a pump on my fiancee's car today. Took about 5 hours total. Not a bad job at all really.
Old Nov 15, 2009 | 04:04 PM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
Re: fuel pump
thanks for the reply but my son and I pulled the tank, replaced MAP sensor and TPS sensor and put in a new pump and the car still won't run right. can't accelerate and idles rough. About ready to burn it.
Old Nov 15, 2009 | 04:21 PM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
Re: fuel pump
how is your fuel pressure? Your pump might not be the issue specially its recently replaced...
Old Nov 15, 2009 | 04:26 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
Re: fuel pump
did you check to see if there was any crap in the tank? You should also do the fuel filter, its cheap and easy to do. And what about the spark plugs, wires and injectors, check them out!
Old Nov 15, 2009 | 07:30 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: fuel pump
Pressure regulator ???
Clogged Cat converter ??
Old Nov 16, 2009 | 11:16 PM
Osbert's Avatar
Re: fuel pump
A fuel pump is a frequently essential component on a car or other internal combustion engined device. Many engines do not require any fuel pump at all, requiring only gravity to feed fuel from the fuel tank. Without a fuel pump, your engine will quickly starve. A bad fuel pump will kill things quickly. You can easily replace and install an electric fuel pump.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
