Right Tail Light Not Working
Old Nov 19, 2009 | 12:15 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
My right tail light is not working, I am not sure when it went out, but I noticed it after replacing the interior carpet and seats. Everything else works great (brake, reverse, binkers, side and left tail (running)). Just the right tail/running light is out and I have replaced all the bulbs with new.
I have put the meter on the sockets and sure enough they are not getting power. Now here lies the problem... The right tail/running lights have a brn/wht wire running to them. I have checked every schematic I can find and it doesn't show up anywhere. The wiring harness is original and yet no manual shows a brn/wht to tail lights. Regardless, I follow the wire up to the front through the harness and continuously there is not voltage. I lose the wire when it goes into the bundled harness under the top left of dash. I pulled the switch and voltage is good across all connections. There is NO brn/wht wire, there is the brn as shown in all the schematics. Has anyone ever seen a brn/whit tail light wire? Do you know where it would be getting its power? Again, it's just the right rear running/tail light.
Thank you!!
Old Nov 19, 2009 | 03:59 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Wire Mire
Due to the fact the left taillight is ok don’t bother tracing it to the front of the car.
The marker/taillights power wire comes in from the left rear of the car then feeds to the right.
You have a bad connection/broken wire between the left taillight and the right taillight.
The brown/white wire was Alpha Momentum crimped to the left tail contact, then run a few feet to the right tail contact.
You merely have to replace/repair that one wire.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 19, 2009 | 05:15 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
Re: Right Tail Light Not Working
Thank you for the quick reply. I wish that were true, it appears by all tests that they have individual power for tail/running lights. Below are pictures to help explain the situation.
Attached Thumbnails Right Tail Light Not Working-pic1.jpg   Right Tail Light Not Working-pic2.jpg
Old Nov 19, 2009 | 05:17 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
Here is second set of pictures to help you, help me.
Attached Thumbnails Right Tail Light Not Working-pic3.jpg   Right Tail Light Not Working-pic4.jpg
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
