door lock problem
Old Nov 23, 2009 | 03:06 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
door lock problem
im having a little issue. first of all i have and after market alarm.
my door actuators click but do not open my door locks .
neither by the alarm lock or the inside buttons.
is there a fuse controlling these?
it got late and dark i didnt pay much attention to it.
Old Nov 23, 2009 | 07:16 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: door lock problem
You're going to have to take the door panels off, clean the mechanisms, check for binding issues, make sure everything it good, and apply white lithium grease.
Might as well check out the thread on rattles, window adjustments, etc. and make a day of it while you have the door panels off.
https://www.thirdgen.org/forums/body...servation.html
Old Nov 24, 2009 | 09:23 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Lock N’ Roll
Did the power locks ever work?
If yes, it’s probably not necessary to take the door panels off because the chance of both the left and right mechanisms becoming binding simultaneously is near zero.
There are 2 protective devices involved with your locks.
The CTSY fuse and the PWR ACC breaker.
The clicking you are hearing might be the door lock relay.
You have one which sends power to both locks.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead. Right grandma?
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Nov 26, 2009 | 09:28 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Lock N’ Roll
Happy Racing!
Also, you need to make sure the relays are fully bolted to the body... They ground through their casings and the mounting bolt. Found that out the hard way.
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
neekolzun
Aug 24, 2015 04:59 PM
g.l.mos
Aug 22, 2015 12:02 AM
