how to wire a kill switch
Old Nov 29, 2009 | 08:39 AM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
can anybody tell me how to wire an ignition kill switch so that the switch needs to be on to start the car?
as a security precaution on an 85 trans am.
Old Nov 29, 2009 | 08:57 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: how to wire a kill switch
If you look down at the starter, there is a purple wire going to the S terminal on the solenoid. That is the wire that actually makes the starter motor do its thing. If you break that circuit anywhere, you will disable the starter motor. It can be found under the dash, at the ignition switch, or, if you have an automatic, if can also be found on the safety switch, that prevents starter engagement with the car in anything except park, or neutral.
Old Nov 30, 2009 | 02:14 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
But the starter can still be hotwired direct from battery in a auto or push started if stick
Best way is to connect a wire through a switch to ground on the neg side of the coil.This grounds out the coil and even if someone hot wires the coil direct from the battery it will not make a spark.If you splice into the coil wire somewhere in the wiring harness no thief will have enough time to find it
Old Apr 29, 2010 | 09:17 PM
thetaman85's Avatar
Can you tell me what color wire i should splice into under the dash? Or in the console if applicable?
89GTAOz
May 16, 2020 09:31 AM
Street Lethal
Apr 30, 2019 12:14 PM
Caspar
Jun 19, 2016 11:19 PM
overdriv
Aug 20, 2015 03:52 PM
355sbcTPI
Aug 19, 2015 04:38 PM
