Starting problem with 84 z28
Old Dec 2, 2009 | 04:21 PM
TigerChris's Avatar
Car: 1984 Camaro Z28
Engine: 350cid from 68-69 SS now 383stroker
Transmission: 5 speed what else?
Axle/Gears: Don't know.
Hey guys, I'm out of ideas here. I have never had any problems with my car starting until now. Just all of a sudden it stopped working. I put the key in the ignition and turn it to start. No clicking of the starter. Just a buzzing sound coming from under the dash. The car has a 350 w/ carb. I took the starter off and had it rebuilt anyways because it looked very old but put it back on and same problem... as far as I know, the neutral safety switch is bypassed cause I can crank it without pushing the clutch. All accessories, lights, radio, blower motor all work with key on run.
Old Dec 2, 2009 | 05:24 PM
TigerChris's Avatar
Re: Starting problem with 84 z28
Great news. I found the problem. After a brain-fart, I checked the neutral safety switch bypass. Turns out, the jumper wire had fell out. Re-installed and cranked.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
