No Power change at fuel pump relay on/off
Old Dec 11, 2009 | 05:06 PM
MannMadeCustoms's Avatar
I have an 86 Trans Am. The 5.0 was replaced a couple years back with a crate 350 Pro-Torque. All the origional gear put on new engine. The car ran good till about two years ago when I parked it (got a minivan and a truck/kid,work). But I have sold the mini van (Take that mid-life crisis) and now sinking what little money that gave me into the Trans Am.
There is no fuel to carb. I checked at the fuel pump relay switch and I am not reading any difference on plug from ignition on/off. I don't know if this is normal, but I need help, Anybody?
Old Dec 11, 2009 | 09:09 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: No Power change at fuel pump relay on/off
The fuel pump should prime with the key on - if you can't hear it priming, the fuel pump relay may be bad. Swap it out and see if the fuel pump primes then.
This is assuming that your' running the stock cc carb - if it's an aftermarket carb then the relay is not doing anything.
Old Dec 12, 2009 | 12:47 PM
It has a mech. fuel pump. I was wondering if it (fuel flow) is controlled by the relay if infact it even is the fuel relay? ( I am not all that wrench gifted as one can tell)
I removed relay and didn't get any change with volt meter with ignition on/off.
It is located in the middle of two others on the firewall drivers side.
Last edited by MannMadeCustoms; Dec 12, 2009 at 12:51 PM. Reason: needed to add some more info.
Old Dec 12, 2009 | 06:31 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by MannMadeCustoms
It has a mech. fuel pump..
Did it run correctly with mech pump before being parked?
If it has been parked for 2 years there is probably no fuel at the pump and mech pumps won't self prime well if dried out.
Need to get some fuel into pump
Old Dec 12, 2009 | 08:13 PM
Thank you! I will try that when the rain lets up a bit. Mother nature installed a brand new mud floor to my outdoor shop!
RazorN8
Jan 7, 2022 11:44 AM
mustangman65_79
Apr 14, 2017 05:37 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
