wiring harness compatibility
Old Dec 11, 2009 | 07:20 PM
george 88gta's Avatar
Having a lot of intermittant problems with my 1988 TransAm GTA. I have found a few damaged/broken wires. Plan is to replace the engine compartment harness. I have located a couple, but I want to insure they will work. Best I can do is ask for a pic since they are not in the local area. My car has the "F" engine, factory A/C, MAF and the cold start injector. The cable enters the body down in the right fender well, a large connector. Are the Camaro and Firebird harnesses the same(assuming it came from an F or 8 engine)? Any way to tell by part number?
Old Dec 14, 2009 | 12:08 AM
Pocket's Avatar
Car: 91 Trans Am
Re: wiring harness compatibility
86-88 TPI harnesses were essentially the same
Camaros had cable speedos so the VSS wiring will not be there if you put it in a bird
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
