Need help with fan wiring....
I currently have a 86 firebirdtrans am the problem is i have an electric fan that is wired to a switch, i was wondering how i could wire it to my ignition wire instead of my battery.....and is it a good idea?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need help with fan wiring....
i keep forgetting to hit the switch when i drive..its really annoying...i would like it to come on when the car starts so i can skip the hassle of cooking my engine
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
do you have a carb or tpi/tbi engine?
if you have a tbi/tpi , you can use a switch in your console
with a negative wire and hook these up on your original wiring on the fan relay!
if i remember it hase a 4 wire relay and you must bypas the green/white
wire with a negative wire/switch.
my relay was located on de passenger side behind the headlight!
do you have one or two electric fans?
please tel some more info about your car!
dennis
dennis
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Fan Plan
The RUN circuit is activated by the key.
One way is to connect the fan relay coil to the output of the GAGES fuse.
Happy Racing!
If People Drove Any Slower They’d Be Going BackwardsWhen you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
i have an 86 firebird trans am with a 350 short block...someone removed the airblower(for exhaust system) and the interior was in shreds when i got it....i bought it for 350$ though so i cant complain.....but wouldnt the gauges fuse only be activated with the lights? and also my speedometer is broken....and i think the RUn wire would be most efficient..
Transmission: 765R4
Fan Plan
……i think the RUn wire would be most efficient……
There are many places which to access the RUN circuit from.
One is the GAGES fuse.
.…..but wouldnt the gauges fuse only be activated with the lights?
The GAGES fuse powers the gages.
The INST LP fuse powers the instrument lamps.
Happy Racing!
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Car: 82 Z28
Transmission: T400
Simply grounding the dark green/white ECM wire will set the fan to turn on with IGN power. The fuse is shared with the ALT which receives IGN power from the fuse block
Transmission: 765R4
Fan Plan
Originally Posted by vetteoz;
But a smart person would not run the fan direct off that fuse ; too much current draw through the circuit.
You need a relay
You need a relay
That’s why all the smart people which read post 7, read the line:
To accomplish that hook the fan relay to the RUN circuit.
Also, you quoted that line.
Happy Racing!
Car: 82 Z28
Transmission: T400
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The Short Answer:
The Long answer:
Do not simply splice the Fan into a "Switched Power" or "INGITION" or RUN" wire. The Fans usually get a dedicated 25 fuse in the fuse box and splicing into some random "Fat Pink Wire" is not advisable. ( at least check to see if a Fan fuse is present and working into your fusebox, If so than use it as your power source ! ) As it is currently wired you will forget it and the engine will cook. If you wire it to an ING wire (usually pink) than the fan will operate at all times and your 350ci will hardly ever reach operating temp.
Go with a Block mounted sensor,.......
Use a temp switch for automatic control, summit carries them
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
As a reminder, get yourself one of those rocker switches that have an LED light on it, that way if you see no light, then the fan isnt on.
Get a voltimeter and start checking each fuse with the highest amperage. Note down the ones that are HOT with key to ignition. Then put key back to off position. get back under and check if the HOT fuses are now off. If you find one that is off when off, and one that is HOT when switched to ignition, then your good to go.
. My next mission, hook up my fan wiring correctly. Thanks guys. Joined: May 2009
Relay= Autozone
Freebee= look at the picture. I highly advise you that this is theeeeeee wrong thing to do, but since you need a free jerryriged job, then here you go.
Car: 82 Z28
Transmission: T400
Car: 82 Z28
Transmission: T400
Yes but if you don't spent $$ on a relay then you risk burning your car down which could cost more than the relay and a bit of wire
Why?
Why?
The guy needed a freebee so I gave him one. I understand the consiquences but all that Im doing is giving advice,,,bad, easy, free and extremely lazy workmanship. I see it this way, he needs the cheesiest way to work his fan right? Well it's his car, not mine. Im sure he's aware of the reprecussions but its his choice. I also mentioned about going the relay route. I gave supported the lazy cheap way, and the time consuming right way.
