code 53 comes and goes
Old Dec 18, 2009 | 09:06 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
on my 85 trans am, i replaced the battery last week and now i am getting a code 53 when i flash the diagnostic light and the voltage on the guage fluctuates between 13 and 18 volts code 53 says High voltage at battery OR High voltage at exhaust gas recirculation valve OR Voltage reference error, could the battery just be bad or is it more likely its the alternator?
thanks
Old Dec 18, 2009 | 09:35 PM
Spinum's Avatar
Re: code 53 comes and goes
On the tree it shows regulator . Now right before that it says amp check.My guess would be the voltage regulator in the Alt.Clear the code and try again.If it was flow exaust gas you would get a crank sensor warning in the tree.If you replaced the battery within a close CCA there is no reason for a draw as the run capacitor would keep even flow to the return unit.My guess is bad alt or bad ground.You want to be careful with that spike as if the amps are high they can fry your ECM.
Old Dec 20, 2009 | 07:36 AM
thetaman85's Avatar
thank you, i cleared the codes and it came back so i replaced the alternator, easy fix, all is well
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
