having some hatch issues
Old Mar 13, 2010 | 07:18 PM
  #51
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: having some hatch issues
Originally Posted by Maverick H1L
The motor won't stay down if the slider doesn't connect to the bracket through the motor housing, which is obviously broken to pieces.
If the hatches are locked, it's simple to get them open. Move any crap you have to to get the rear seat folded down, lay down and crawl into the hatch, pop the light out of the rear panel, insert a screwdriver into the slot that is exposed, and turn the screwdriver. Hatch will pop, and you have a motor assembly.
BTW, I know I was going to send you the stock intake air box, but I'm using it at the moment because I'd rather not damage my new MAF by knocking the elbow off of it. I'm going to try to get some more intake piping and fab something up, but my hours just got cut again and I have to watch my spending.
intake box? i dont remember us talking about that, of course iv slept since then aswell so i might have forgotten about it.
and ill try that, just have to make sure i get a 90 style hatch moter right?, iv read that there are a few different styles
Old Mar 13, 2010 | 08:21 PM
  #52
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Yeah, the air filter can and everything between it and the intake bellows (with the exception of the MAF)...
Anyways, the hatch motor is the same style found on cars between 86 and 90/91 model years. I believe that in either 90.5 or 91.5 model year, GM went to a different design for the pulldown unit.
Old Mar 13, 2010 | 09:59 PM
  #53
Engine: L31 350
still dont remember us talking about that, and okay so all i have to do is look for a gm 86 - 90 and hind the moter, anyone know what size bolt is holding it in?
Old Mar 13, 2010 | 10:09 PM
  #54
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Originally Posted by evilemokid94
dave you should know better than anyone that my car is in parts right now so i doubt ill be driving it for awhile, can anyone post a list of ALL the cars that have the same time of hatch moter assemblys as ours? and i have two junkyards that are close to me that have SEVERAL and i mean over 20 trans ams and camaros each but most of the hatchs are locked so its hard to pull the moter off like that lol
If its closed, all you have to do is climb inside and crawl to the back. Tear apart the plastic cover that hides the pull down motor. Then remove the black box that (piggybacks the pull down assembly that mounts with one bolt) has a long black plastic covered cable. Then insert a flat head screw driver into the slot and turn. Pop goes the weasel. the trunk is now open. That little slot is for the aftermarket lock cylinder rod.
Old Mar 13, 2010 | 11:00 PM
  #55
Engine: L31 350
what black box are you talking about?, as you can tell im not very good with this kind of stuff
Old Mar 14, 2010 | 06:20 AM
  #56
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
They did change the pulldown assembly, but the motor and housing was still the same. Just bring your old one with you and compare it at the JY. All you have to do is put your old pulldown assembly onto the new motor.
Old Mar 14, 2010 | 08:32 AM
  #57
Engine: L31 350
ok, thats a good idea, i didnt even think of taking it with me to compair them
Old Mar 14, 2010 | 08:48 AM
  #58
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
I fought a hatch motor assembly yesterday afternoon. The keys were lost. So I unbolted the top hinges, removed the hatch bolts, then removed the entire assembly. Then I could easily unlock the catch. Would have been much easier if I could have accessed the 2 trim panel screws on either side of the lock
I wish this thread came along a day sooner. I would have been looking for Caddys.
Old Mar 14, 2010 | 09:20 AM
  #59
Engine: 2.7L V6
Axle/Gears: 4.41
Since nobody's said yet, there are 3 13mm bolts holding the bracket to the tail panel of the car... And a 10mm bolt on the lock cable assembly, and another bolt for the ground wire... Not to mention you'll need either a philips screwdriver or 7mm nut driver to get the rear trim panel off just to get at the thing.
Old Mar 14, 2010 | 09:59 AM
  #60
Engine: L31 350
yeah i know how to get the trim pannel off, just needed to know which bolts are holding the moter onto the car so i can pull it off., and blind driver this thread has been around forever, since last december i believe is when i made it
Old Mar 14, 2010 | 10:05 AM
  #61
Car: 1986 Trans Am
Engine: 5.0
I got the above post on my iPhone right after I fought the old motor
Motor was free from my old boss.
Old Mar 14, 2010 | 10:09 AM
  #62
Engine: L31 350
cant beat that, hatch moters seemt to be pretty cheap at the yards
Old Mar 14, 2010 | 11:12 PM
  #63
Okay, forget what I said about the black box. If your hatch looks like this, then look at the arrow (#1). That little black hole that it's pointing at, its the aftermarket lock cylinder shaft slot. If your able to remove the panel or remove the trunk light, then insert a small flathead screw driver in there and turn and pop. your in. Also if your lucky, remove panel that hides your spare tire. If there is already a aftermarket lock, then the cable that swings to the left (in the picture), should be hanging and probably tucked just behind the panel. All you have to do is insert the flat head screw driver into the opaque plastic cylinder (#2) and turn and it'll pop open the trunk too. Now on the other picture red is the pull down motor ok. Now the the blue line reps the black cable that has the opaque cylinder on it. If there is that aftermarket lock with the shaft, then in yellow, the opaque cylinder will be hanging around this area behind the trunk panel. Sounds confusing? If so let me know and I'll call you on your phone to explain.
Attached Thumbnails having some hatch issues-pull-down-motor.jpg   having some hatch issues-interiorblackhatchstoragelightb1.jpg
Old Mar 15, 2010 | 09:34 AM
  #64
Car: 1988 GTA
Engine: 400 CI
I read in another post that all you have to do to manually pop the hatch from inside is pull out the cargo light. Then you can use a screwdriver to pop the hatch. Haven't tried it myself though.
Old Mar 15, 2010 | 12:23 PM
  #65
I heard this too. But I cant verify because my trunk panel doesnt have a trunk light.
Old Mar 21, 2010 | 07:15 PM
  #66
Engine: L31 350
well i bought a new moter but i dont know what year, it looks like mine but my lock isnt coming out the side, it was bolted onto the latch, so i need to take my old one and switch them over.
Old Mar 21, 2010 | 07:40 PM
  #67
Engine: L31 350
is there any way for me to take that cable off my old latch to put it on my new latch?, i was just going to take the latch off but its rivited on so i cant take it off.
Old Mar 21, 2010 | 07:41 PM
  #68
Car: 1986 Trans Am
Engine: 5.0
I took mine off with the plastic that covers the lock. Big right hand and some twisting force worked for me
Old Mar 21, 2010 | 07:56 PM
  #69
Engine: L31 350
im going to upload some pictures of my new moter, if you can tell me if i can do this, i took off the old lock because i forgot mine had the cable.
Old Mar 21, 2010 | 08:20 PM
  #70
Engine: L31 350
  #71
Engine: L31 350
Old Mar 21, 2010 | 08:21 PM
  #72
Engine: L31 350
Old Mar 21, 2010 | 08:22 PM
  #73
Car: 1986 Trans Am
Engine: 5.0
I was referring to the plastic on the cylinder.
You can probably just grind/drill the rivits and install new rivits/bolts depending how much clearance there is.
Old Mar 21, 2010 | 08:31 PM
  #74
Engine: L31 350
thats what im talking about, on the left side of the moter thats on my car now it has the black cable running from it to my lock, but this one doesnt, it had a silver lock on the front of it before i took it off at the junkyard.
Old Mar 21, 2010 | 08:46 PM
  #75
Engine: 2.7L V6
Axle/Gears: 4.41
Let's go back a bit. Does your car still have the lock riveted to the tail panel, and is the nylon cable end attached to it? If not, reattach the lock to the tail panel (will need to remove the tail lights and the license bracket to do this), and push the nylon cable end onto the lock, engaging the pawl in the cable with the shaft on the lock.
After the cable and lock are set, mount the pulldown unit to the tail panel with the 3 13mm bolts, loosely, and connect up all the cables. The motor should return to the full up position. If not, you will need to push down on the switch until the motor comes to the bottom and flips the reversing switch, and release the position switch so that the motor will come to the full up position. Then, take the pulldown end of the lock cable, engage the tangs on the housing with the slots in the motor and the release tab inside where this sits, and push the remaining part towards the screw hole until it lines up.
It's too dark to take pics or a vid now, but I can try tomorrow if you'd prefer. :edit: However, I have an assembly that will look a bit different from yours since I also have installed the hatch release solenoid. Just an FYI.
Old Mar 21, 2010 | 09:00 PM
  #76
Engine: L31 350
yeah the black cable is still on my car running to my lock and to my hatch moter.
Old Mar 21, 2010 | 09:08 PM
  #77
Engine: L31 350
i need to take this cable here and put it on my new moter.
Old Mar 22, 2010 | 12:25 AM
  #78
Look at this picture. On my lock mechanism, there is a bolt. If you take off this bolt in yellow, the black case holding the cable should slide over and lift right out.
Old Mar 22, 2010 | 03:00 PM
  #79
Engine: L31 350
then i can just put the cable on my new moter, ok thanks guys
Old Mar 22, 2010 | 06:25 PM
  #80
You really dont need the cable/case thingy. All it is is just the housing for the original lock cylinder. I have mine just hanging inside the cargo cover. It also serves a good purpose if the motor burns out while the lid is closed. Happened to me once. I just removed my spare tire panel cover and turned the rectangle slot inside the round case and pop. I got my hatch open.
Old Mar 22, 2010 | 06:38 PM
  #81
Engine: L31 350
well its on the moter for a reason and i dont know, im weird like that, i was everything to look like it should or be like it should
Old Mar 22, 2010 | 06:42 PM
  #82
Engine: L31 350
besides how would it unlock the hatch if its not attached to the moter?
Old Mar 22, 2010 | 08:11 PM
  #83
Easy. the rectangular slot inside the round white cylinder turn either weft or right (forgot which way). SO once it turns, it'll pull a metal wire/cable that is inside the black plastic tube/cable. WHen the wire gets pulled, it'll pull a piece of latch that'll catch and other latch that is inside of the motor assembly which will in turn, unlock the latch. SO no, you dont need it. You can always go with a aftermarket lock cylinder that suppies a lock shaft that extends into the slot on the assembly.
Old Mar 22, 2010 | 08:12 PM
  #84
Ill provide pictures if your confused.
Old Mar 22, 2010 | 08:13 PM
  #85
Engine: L31 350
pictures would prolly be best
Old Mar 22, 2010 | 08:16 PM
  #86
Well Im at school right now so Ill post up the pics tommorrow. Sound good?
Old Mar 22, 2010 | 08:23 PM
  #87
Engine: L31 350
sounds good to me, im going to bed soon anyways, its rainy here so that always makes a slow day, normally when i get out of school i check on my post and PMs here before i go out and for on my car so i should get them some time tomorrow
Old Mar 22, 2010 | 08:24 PM
  #88
OK. lock the latch like if you just closed the hatch. Now right in were the yellow circle is at, there is a little catch/lever. push the lever and the latch will unlock. It's purpose is for the factory lock that is incased with the white cylinder/black cable/ case that piggy backs the whole lock assembly.
Old Mar 22, 2010 | 08:30 PM
  #89
Engine: L31 350
yeah i know how to lock and unlock that manually, that picture is of my new moter, so the main question im asking is if i can take that black cable that on my old moter, i have it circled in red in a picture, and put it on my new moter.
Old Mar 22, 2010 | 09:00 PM
  #90
Yes. Its just part of the factory lock mechanism. You really dont need it. I took mine off and I put in a electric solenoid from a 87 IROC-Z so that I can open my trunk wirelessly with my alarms remote. Sorry if I gave you the run around.
Old Mar 22, 2010 | 09:09 PM
  #91
Engine: L31 350
its fine, you along with the other members were just trying to help, i thought i messed up because i took of the silver lock solenoid off because i thought the lock on my car would fit, then i noticed that my new one didnt have that black cable so i felt like i got screwed
Old Mar 22, 2010 | 09:29 PM
  #92
Its all good bro.
Old Mar 22, 2010 | 09:31 PM
  #93
Engine: L31 350
tomorrow im getting my new battery and putting in the new moter and my new hatch light and hope they work.
Old Mar 22, 2010 | 09:32 PM
  #94
Engine: L31 350
another thing, i pulled this off a car that had all the power options even the power hatch so that wont effect anything will it?
Old Mar 23, 2010 | 07:08 PM
  #95
Engine: L31 350
well i got the moter installed and everything hooked up except that one damn wire, i cant figure out where it goes, so can anyone look back at it and try to tell me where it goes? i have everything else hooked up and i cant get the moter to do anything so i think its that wire.
Old Mar 23, 2010 | 07:13 PM
  #96
Car: 1986 Trans Am
Engine: 5.0
I got my "new" hatch motor installed a few days ago.
There is a blue and a white wire. I forgot where the white goes, but I think the blue is positive? I think the blue goes to the red wire coming in from the sail panel.
I hope someone else chimes in for the fun
Old Mar 23, 2010 | 07:17 PM
  #97
Engine: L31 350
this wire is black, here are some pictures
Old Mar 23, 2010 | 07:18 PM
  #98
Engine: L31 350
Old Mar 23, 2010 | 07:47 PM
  #99
Engine: 2.7L V6
Axle/Gears: 4.41
I'll look at mine after work tomorrow if the rain quits sometime here... Either that or I'm going to have to rearrange the stuff in the garage again .
Old Mar 23, 2010 | 07:52 PM
  #100
Engine: L31 350
my garage is full of parts, so i cant put my car in there sadly, so i need to replace my weatherstripping soon :/, anyways i even replaced the hatch fuse and checked al the conections on the moter and they seem to be good, i have power running to everywhere else so it has to be that single plug!
