New harness for TPI /w MAF
Old Dec 28, 2009 | 04:55 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i'm about to buy harnesses for my 2 f-bodies (TPI 86-89 MAF) but i cannot deciede which one to takie:
http://painlesswiring.carshopinc.com...id/43886/60102
http://www.speedscenewiring.com/ssw/...ef59a0ce8256d4
http://fuelinjectionconnection.com/gpage.html (bottom of page)
The last one is the cheapes (and actually i'm on budget) but i don't know about quality, any body heard of them or bought one from them??
Or maybe any other place wher to get such harness in good price.
best regards
Old Dec 28, 2009 | 05:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: New harness for TPI /w MAF
You realise those harnesses are intended for a TPI retro fit into a non EFI car; not as replacements for stock?
Old Dec 28, 2009 | 06:07 AM
WASyL's Avatar
actually i didn't know that, are there any replacement ones? any brands, webpages etc?
i cannot use them as replacement?? if not, why ?? i don't mind if relays and stuff will be in placed different than stock or if there are no EGR, AIR etc stuff as i don't use them wit MegaSquirt
best regards
Old Dec 28, 2009 | 06:28 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You could but those harnesses only do engine management
The factory underhood harness has wires for other things like fans and A/c.Make anything work if you try hard enough
Only source for factory harness would be 2nd hand I suspect
None up for sale at the moment but have seen similar engine only harness on eBay for much cheaper ($200) than those that you linked above
Old Dec 28, 2009 | 06:31 AM
WASyL's Avatar
ok, will one of this would be better choice?
http://cgi.ebay.com/ebaymotors/Corve...item19b87083f9
http://cgi.ebay.com/ebaymotors/Corve...item19b89a17a5
best regards
plm99
Southern California Area
Nov 16, 2015 05:21 PM
amargari
Nov 10, 2015 02:09 PM
1nastygta
Sep 24, 2015 08:58 AM
86White_T/A305
Sep 21, 2015 05:28 PM
