couple radio questions
Old Jan 9, 2010 | 08:10 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
first of all, does the 89 camaro have the wiring harness of the 88, or the 90? my 89 had the wiring harness for the radio missing, so I grafted on the input that matched a yellow letter radio that I already had, but now I'm wondering if I did the right thing
also, this radio I have emits a static out of one speaker, as long as the radio is on, no matter what the volume level of the radio. the only way to stop the static is to turn off the radio. i don't think it's the speaker because it worked fine with the old stereo, does that sound like a faulty radio to you?
Old Jan 9, 2010 | 11:45 PM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: couple radio questions
89 model cars had the newer style plug, the colors are the same though so you did the right thing. As far as the static the speaker might have a bad connection or the radio is bad. It's probably the radio if it worked fine with the old stereo
Old Jan 10, 2010 | 01:57 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
This is from an inactive web site, but the info is still useful. Seems like 1989-1990 was a transition year for the factory connector.
File Type: pdf
Old Jan 10, 2010 | 04:27 AM
58mark's Avatar
thanks, mine has the second one on it. I almost wish I has put the earlier harness on it, it would make finding a working white letter radio so much easier
Vintageracer
Jan 10, 2020 05:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
