i have a cut wire?
Car: 88 IROC Z/28-under re-construction
Engine: 5.7 Tuned Port
Transmission: It's in there....
Axle/Gears: 9 bolt Borg-Warner
i have a cut wire?
i need help again, i have this dark brown wire out of the electronic module thats on the firewall.this wire leads over to the oil sending unit area.i don't know how long it was and have no idea because i didn't cut it.i looked on my schematic disc and i just can't locate where it goes. 1987 5.0 TPI harness. if you can help i would be grateful
damn! you can't see the color but it's where the phillp's is pointing
Re: i have a cut wire?
That is the ESC module
http://www.austinthirdgen.org/mkport...rk_control.jpg
According to that, brown is ground. Easy enough. Confirm it by pin location rather than color
i knew it had to be simple it just didn't want to melt a part somwhere.
thank you!
thank you!
db057
Aug 11, 2015 10:11 PM
