gauges lights at night
Old Jan 18, 2010 | 01:54 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
hey yal. the light for my gauges at night went out durring the summer and i just put in a switch in for the head lights/ dome light being told that usually is the problem. all fuses are fine.
where else should i look to fix this problem or did the light just fail?
thanks
Old Jan 18, 2010 | 02:19 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Nite Lite
Does the dome light now work?
Old Jan 18, 2010 | 04:22 PM
Car: 90 formula
Transmission: auto
Re: Nite Lite
dome light has always worked.
Old Jan 19, 2010 | 10:49 AM
NINÅ's Avatar
Transmission: 765R4
Nite Lite
If the HVAC panel lights you have a discontinuity from the INST LPS FUSE to the cluster in the dash.
Look for a defective or dirty contact in the connector going to the dash.
Then look for a broken trace on the dash circuit board (hard to see).
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime, and the nitwits that need headlights for a little rain
Old Jan 19, 2010 | 02:24 PM
Car: 90 formula
Transmission: auto
Re: Nite Lite
thanks. ehhh sounds like its going to be a pain in the ***
Old Mar 29, 2014 | 08:22 AM
88trans350's Avatar
Re: Nite Lite
My ip lights were on and I decided to pull out my radio ., and then they weren't illuminated anymore... Any ideas
Old Mar 29, 2014 | 08:23 AM
88trans350's Avatar
Re: Nite Lite
Ip lights worked before I pulled my radio out then the lights weren't lite up
Old Apr 1, 2014 | 05:05 PM
NINÅ's Avatar
Transmission: 765R4
Nite Lite
First check the TAIL fuse.
If that’s OK use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) to probe the orange wire at the switch.
Is there power there?
If yes probe the
brown wire on the switch when the switch is in the on position.
Happy Racing !
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
BRoss99
Aug 10, 2025 05:08 PM
Ghettobird52
Jul 5, 2024 11:18 PM
GTAman
Mar 15, 2019 11:40 AM
chazman
Aug 28, 2018 03:25 PM
Omega
Aug 10, 2015 12:46 PM
