Cheapest way to delete vats
Old Apr 2, 2014 | 07:56 PM
crzymike's Avatar
Ok. I am almost sure the vats module is bad. What is the cheapest way to delete it and get my 1992 firebird started again. The history..
I got the car from its death bed with no KEY. The ignition cylinder was broke and did not need a key. After buying a 15 pack of resistors and taking the time to insert one resistor every 5 minutes to start the car. I finally got the car started. it turned out to be the key code 8.
Well about 2 weeks ago I finally had time to start working on the car again. Went out to start the car and nothing. NO starter and no fuel. So I ordered a new ignition cylinder and replaced it. No luck. car still will not start. So I decided to try a new resistor with no luck. So I don't want to get a new key cut for the new cylinder until i figure out why it will not start..
Security light will come on and then goes off. I did change the resistor to another one with the incorrect value. The security light comes on and doesn't go away. But once I change out the resistor to the correct one the security light goes out. but still can not start the car. So I have come to the conclusion that I want this system gone. So back to my question. Whats the cheapest way to delete the vats all together...
Old Apr 2, 2014 | 08:07 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Cheapest way to delete vats
I am pretty sure you'll have to get a custom tune to turn it off in the ECM at this point. I haven't done this yet, but I know that plenty of other members will be able to suggest good people to help you with the tune.
Old Apr 2, 2014 | 08:27 PM
crzymike's Avatar
After reading some other post here on this wonderful board I think a reflash may be in order..
I just got off of eBay and ordered this bypass.
http://www.ebay.com/itm/281179660936...84.m1497.l2648
I will just have to buy one less 12 pack of beer this payday.
will post a reply to let everyone know if it works..
RS Reaper
Oct 17, 2018 07:52 PM
88CamZ
Oct 8, 2015 10:29 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Damon
Sep 26, 2015 04:29 PM
