SES light code question
Old Jan 28, 2010 | 02:09 PM
mascarpone's Avatar
recently my my SES light has been coming on at odd times so i hooked up the jumper wire to the test terminals and it flashed 3 times paused and flashed 2 times. the haynes manual said it was something wrong with the baro sensor circuit. I have never heard of the baro sensor could anyone please explain what the baro sensor does and possibly give me an idea where to start checking the problem? i have an 87 firebird 2.8L rebuilt.
Old Jan 28, 2010 | 02:46 PM
Pocket's Avatar
Car: 91 Trans Am
Re: SES light code question
MAP sensor
Carb cars used a barometric sensor, EFI MAP. Same thing, just baro is open to the atmosphere, MAP is ported to the intake vacuum
Check the rubber vacuum line to it before you replace the MAP
Old Jan 30, 2010 | 11:27 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
For your 87, that code is referring to an EGR system error. The parts for this are the other 2 parts mounted to the ignition coil bracket. As said before, check the vacuum lines running to the valve for breaks and clogging.
BTW, don't believe everything you see and read in Haynes... I've spotted a few errors in there.
:edit: All of the above only applies if you didn't make a typo and you're actually putting out code 33, which is for the MAF sensor, and is the same problem I'm having.
Old Sep 26, 2010 | 02:49 PM
Tank91RS's Avatar
Car: 1991 Camaro RS
Engine: Carb 350ci bored .40
Axle/Gears: 2.73:1
Originally Posted by Pocket
MAP sensor
On a 89 Firebird Formula ws6 where would this all be at?
Pulled the codes from mine and got code(s) 32 and 54
Which are the Baro Sensor Circuit and m/c Solenoid. (Both seem to be connected to the Solenoid, so im thinking thats what needs to be replaced)
eightsixseven
Dec 16, 2024 01:50 PM
redmaroz
Aug 16, 2015 11:40 PM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
