Need help with an SGI-5C **solved**
Old Jan 30, 2010 | 02:58 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Engine: Freshly rebuilt 350 with goodies.
Transmission: 700R4 w/ 2000 Stall
Hi all, I'm trying to get an 87 TPI ECU to play nicely with a 91 700R4 VSS and speedo. I've tried all combinations and no matter what, the ECU always reports the same speed in TunerPro. I can get the speedo to change, but all of the outputs give me the same speed from the ECU, which is 2x too fast. I'm completely lost.
SOLUTION: Turns out the previous owner tried to wire the VSS into the ECU, but left the buffer box and it's wires. I cut the brown VSS wire (A10) on the ECU and put it on OUT4 , and the speedo wire on OUT1. All switches were off. This got the speedo and ECU to match, finally some soft calibration to fix the 3.73 rear end. I just wanted to put the solution here in case someone else does this swap and has issues.
Old Jan 31, 2010 | 11:12 AM
BruceEmbry's Avatar
Car: 82 Ponitac Firebird
Transmission: 4L60e/TCI TCU
Re: Need help with an SGI-5C (ECU speed never changes)
HI,
The 87 TPI ECU accepts 2000 PPM input. Check the configuration on the SG-5. Connect the 2000 PPM output to the ECM VSS input.
Old Jan 31, 2010 | 01:09 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Originally Posted by BruceEmbry
HI,
Yeah I know, but all of the outputs (8k,4k,2k) give me the same reading, always 2x too fast. I'm beginning to wonder if I have a bad box.
Old Jan 31, 2010 | 05:44 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Ok so I think I figured it out. I unplugged everything from the SGI box, which should disconnect the VSS from the ECU, but sure enough I got the same speed reading So I think that when the previous owners did the engine swap they left the VSS buffer from the old engine in the car, but disconnected. Tomorrow I will look for the brown VSS wire on the ECU and run that to the SGI. There is only one VSS wire into the computer right?
Old Jan 31, 2010 | 07:24 PM
Pocket's Avatar
Car: 91 Trans Am
Correct
It looks like this, but it sometimes white
The circuit
http://www.austinthirdgen.org/mkport...SS_V8_vinE.jpg
Connect pin F to pin C
Old Jan 31, 2010 | 09:43 PM
X-Ravin's Avatar
Car: 91 Camaro RS
Yeah I found the yellow VSS buffer for the 1991 305 that was in the car originally, but the pin that should go to the ECU isn't connect to the '87 ECU because I can unplug it and still get a speed reading on the ALDL (2x as much to be exact). Which leads me to believe that they just ran the sensor directly to the computer (note I get no reading until about 20-25 MPH). So I will have to find the ECU VSS input wire in the harness, cut it and run it to the SGI 2K out. Keep your fingers crossed, I'm so close to having my new baby running perfect!
stickychinsac
Aug 31, 2015 06:06 AM
Copperhead
Mar 26, 2015 01:51 PM
jeff91z28/l98
Jun 30, 2013 10:40 PM
Copperhead
Jun 13, 2013 11:51 PM
JekyllandHyde
Jul 28, 2012 11:58 AM
