another vats q's
Old Feb 5, 2010 | 01:47 PM
supamaro383's Avatar
Car: 92 RS
Engine: 383 FIRST TPI OBDII DBW
Axle/Gears: 3.73 POSI DISK
another vats q's
my 1991 rs tbi is not starting no SECURITY light will turn on i guess it my vat no cranking nethier no primeing. i change the lightbulb so yes the security light works any idea guys before i take this thing apart
Old Feb 6, 2010 | 07:34 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: another vats q's
When you turn the key to the on position, does anything happen? Does the SES light come on? I would check the fuse near the battery, as it powers the ECM and fuel pump.
Old Feb 6, 2010 | 07:41 AM
bungalows's Avatar
Here is a sure fix
http://newrockies.ca/vatsbypass/
Old Feb 6, 2010 | 07:50 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
It may not be a VATS issue though. If the VATS system doesn't enable the starter, then the security light will remain lit, and it won't let you try again for 5 minutes. I found out the hard way when my ignition cylinder stopped reading the key resistor. Also, when you turn the key to the on position, the security light should blink once, then go off.
Old Feb 16, 2010 | 01:10 AM
89rser's Avatar
i love that link, i plan on buyin one from the guy, its well worth the money if it works..
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
