i need some help in finding my power door lock fuse
Old Feb 6, 2010 | 06:19 PM
joshs90camarors's Avatar
Car: 1990 camaro rs
Engine: 5.0
Transmission: 4 speed auto w/od
i have a 1990 camaro rs and my door locks are goin crazy,every other day it runs my battery dead and i have looked everywhere and cannot find the fuse or relay anywhere,ive called different auto places and none of them tell me the same thing,one told me its a 20 amp fuse and the other told me its a relay,but if someone could help me out it would appreciated
Old Feb 6, 2010 | 08:31 PM
wwwyzzerdd's Avatar
Car: 1988 IROC Z
Engine: 350 5.7L Carb'd
Axle/Gears: Disc 2.77
Re: i need some help in finding my power door lock fuse
that doesnt sound like a fuse, sounds more like a relay, not sure where that is located, but if it helps any, heres a diagram for the fuses, the power locks are fuse #15 fuses are located under the steering wheel on the left side, in the dash
yours may be different, idk if your fuse box is the same as mine
Attached Thumbnails i need some help in finding my power door lock fuse-fusebox.jpg
Old Feb 6, 2010 | 09:33 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
It should be the fuse labeled "PWR ACC", stock is a 35A.
Old Feb 6, 2010 | 09:58 PM
Car: 1990 camaro rs
Engine: 5.0
thanks i thought that might be it but i wasnt for sure cause it said pwr acc and i didnt know if it powered the lights or somethin,and the diagram helps out alot because the cover didnt come with it i appreciate it
Old Aug 20, 2012 | 11:23 AM
popitas2's Avatar
Car: 1988 Iroc z
Transmission: f4
My doorlocks are going batty also. Anyone know the fix?
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
