msd set up (help me)
Old Feb 7, 2010 | 12:52 PM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
currently have hei on my 283 in my 84 z, want to step up to msd . so i went to the hotrod shop and they said to go with
5520 street fire box
8361 dis. with vac.
8207 ss coil
if i go this way will i have to cut up the stock conections going to the hei???
and what would u put in? pls give me suggestions thanks SEAN.
84 z t5 four bolt 283 40over flat tops cam sinngle plain 650, etc etc
Old Feb 7, 2010 | 01:05 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: msd set up (help me)
You'll only be using the switched +12v and the tach wire from the HEI, but you shouldn't have to do any cutting.
Old Feb 7, 2010 | 01:12 PM
84z .....'s Avatar
so ur saying that the plug for the hei will plug to the point dis. ?
Old Feb 7, 2010 | 01:31 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's not a points distributor, it's a magnetic pickup and has no electronics of its own. You'll be connecting the factory harness to the MSD. You can put connectors on the end of the box's wires for that.
Old Feb 7, 2010 | 02:08 PM
84z .....'s Avatar
thanks im not real good when it comes to electricity but i understand now
toronto formula
Nov 10, 2015 06:17 AM
LittleFranks
Sep 17, 2015 12:22 PM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
