Fuel pump relay..... Help
Old Feb 8, 2010 | 03:53 PM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
Well i've got an 88 z28 5.0 TBI and the other day I decided that I didn't like the tatered and worn wires coming from the fuel pump relay. So I went to the junk yard found the same setup on another car cut it off and brought it home. As I had the wires stripped and was fitting the new connector on, a couple of the wires touched together and arced I realized that I hadn't undone the battery cables. I then dropped what I was doing and unhooked the battery and finished the project. After everything was put back together I turned the key over and the fuel pump didn't turn on like normal. The car will turn over and everything works but the fuel pump. I checked the wires to fuel pump relay and none of them have power going to them. Any Ideas or suggestions???
Old Feb 8, 2010 | 03:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel pump relay..... Help
Check the fuse.
Old Feb 8, 2010 | 05:00 PM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
I have. Double and triple checked. Thats the weird thing I cant figure it out.
Old Feb 8, 2010 | 09:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
did you check the fuse tucked in the fenderwell behind the battery? check all the other fuses - maybe fried the ECM fuse. maybe fried the relay and need to replace - they are about $9 at any parts store.
Old Feb 9, 2010 | 12:17 AM
will_b72's Avatar
Car: 1988 IROC Z28
Engine: 305 TBI
No I wasn't aware there was one there. I'll look around and see if I can find it.
Old Feb 9, 2010 | 07:40 AM
Pocket's Avatar
Car: 91 Trans Am
The fuel pump/ECM's only battery fuse is located near the battery in its own little holder
I dont know what other pump fuse you checked, but it wasnt the correct one
If you suspect the relay, swap it with a fan relay and see if it clicks when engaged. If it clicks and the old one doesnt, then the old relay is dead. No click means its not getting power
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
