VATS = stupid
Old Feb 15, 2010 | 11:42 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
VATS = stupid
So, like most people I know, my VATS is screwed up.
I found the resistance of my key, soldered in the right resistors, and it worked fine.
For awhile.
Now it likes to not work. Most times it'll start on the second attempt (after 4 minutes) Occasionally though, it won't start for 40-45 minutes, and I don't know why.
The resistance is correct, the solders are good, it just...doesn't work sometimes. It'll go through cycles of working for 2 months at a time with no skips, then for a week or so it'll just be nothing but headaches.
Any ideas as to why this is? I'd really rather not go through the hassle of tearing out my entire steering column but...I need my car to start haha.
Old Feb 16, 2010 | 12:32 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: VATS = stupid
why would you need to tear out your column? i never did when i bypassed my VATS, i just found the wires cut em and put the resistor in line, it could be a possibility that while you were soldering the resistors got too much heat which in turn bumps it up, your setup may be just crossing the threshold for resistance, why im not sure but i had a similar issue with my setup, got em too hot and it would do that crazy ill start for you now but tomorrow when youre late for work im gonna leave you stranded deal lol try soldering up a new set and give that a shot
Old Feb 16, 2010 | 12:49 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Re: VATS = stupid
To fix it correctly you have to go all the way up to the ignition...bypassing =/= fixing.
Old Feb 16, 2010 | 01:07 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: VATS = stupid
well when i bypassed my vats its because i got a new steering column without a vats setup, and if you wanna get technical deleting VATS is a permanent fix to a low tech security problem. WOrst idea GM ever had IMO, now atleast lol its just a PITA because 90% of third gen owners end up getting rid of it or spending a great deal of time fighting it
Old Feb 16, 2010 | 11:24 AM
Pocket's Avatar
Car: 91 Trans Am
Re: VATS = stupid
No, you go somewhere inline of the two resistor wires. Either at the bottom of the column or near the VATS module
It can be a permanent solution, but its not hard to reverse. Get the correct key and reconnect the wires
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
djmarch
Oct 2, 2015 10:41 PM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
