headlights - trans am 87
Old Feb 20, 2010 | 07:00 AM
slept's Avatar
okay the headlights on my trans am. i try to put them down manually and one of them doesn't go down when i turn the ****. it jus keeps spinning. anyone know what else i could do to put it down? (or fix this)
Old Feb 22, 2010 | 05:53 PM
bigd077770's Avatar
Car: 1998 Trans Am/1992 Camaro RS
Engine: LS1/5.0L TBI
Transmission: 4L60E700r4
Axle/Gears: 3.23/2.73
Re: headlights - trans am 87
it could be the gear inside the headlight motor is no good, all the teeth wear off after a whil ebecause they are plastic, they sell rebuild kits. you can get another plastic gear for it for it or a METAL GEAR. the plastic one is cheaper but will obviously wear out before the metal one. hope this helps.
heres the link to the plastic gear-
http://www.hawksthirdgenparts.com/fi...pairkit-2.aspx
heres the link to the metal gear-
http://www.hawksthirdgenparts.com/fi...pairkit-1.aspx
Old Feb 26, 2010 | 01:53 PM
Brad5117's Avatar
i pulled mine from the junkyard and the work fine , i just made sure they when down by turning them and they work fine
1992 Trans Am
May 10, 2023 07:19 PM
1992CamaroGirl
Dec 25, 2017 08:45 PM
The_Phoenix
Feb 4, 2016 07:10 AM
DiabolicalRS
Aug 26, 2015 07:35 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
