wireing up a autometer tack to my 91 rs
Car: 1991 Camaro RS
Engine: 383 procomp heads comp 280h cam
Transmission: 700R4 with monster tran. rebuild
ok guys i got a 1991 rs and i need to know what wire to hook my tach wire to any suggestions or where to start looking?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: wireing up a autometer tack to my 91 rs
Need key on 12V and ground obviously
Tap into the factory tacho signal feed going to stock dash, saves having to run new wire from engine bay to new tacho
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
Car: 82 Z28
Transmission: T400
You need the the wiring diagram for your car to identify the tacho signal wire ( usually white ). Usually easiest to tap into it where it comes through the bulkhead plug from engine bay unless you remove dash and tap into the wire where it plugs into the dash unit
Car: 85 Z28 Vert
Axle/Gears: 3:08
Thanks.. I usually don't do any guessing and run it strait from the distributor anyway... sometimes its just as quick as trying to figure out which wire it is..
But i am all up for the quickest way but its not always the best..
ambainb
Apr 25, 2016 09:21 PM
