drivers door window Motor fault
Car: 1986 Iroc Camaro
Engine: 350+
electric motor takes window down fine but when closing goes up about half way then stops wait for a few minutes then it will come up more and so on
any ideas or should i just go for new motor???
Cheers
Mike
Cheers
Mike
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: drivers door window Motor fault
IIRC, a thermal switch cuts the motor when it become too hot. Overheating "may" be due to binding. I'd try adjusting the window before replacing the motor.
JamesC
JamesC
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
^^^Agreed. I replaced the motor on the passenger side door and found that it moved just as slow as the old motor but after I adjusted the window and lubed the tracks it worked much better. I did the same to the driver side and it works great with the old motor still in it. Try adjusting and lubing before replacing the motor. Good luck.
Mark.
Mark.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If you do end up replacing the motor, do a search on here for a thread titled something like "tech article BS" - it has a page to print showing where to drill in the door panel to drill out the rivets holding the motor to the regulator - it's a very easy method for replacing the motor without removing the regulator from the door - I did both sides on mine using this method 3 years ago, and it was fast, easy, and worked very well.
1992 Trans Am
May 10, 2023 07:19 PM
