maybe a ground issue or something?
Old Mar 2, 2010 | 09:22 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I bought my trans am with 2 aftermarket autometer guages on the left pillar. (water temp and oil pressure). Before i did the t56 swap they both worked perfectly and they it up. Now i have finished everything, but ive noticed that they work until i turn my headlights on then the guages go all the way to the right, pretty much says im running at 260 degrees and like 100 psi oil pressure. I can turn the dash lights all the way on and they will work, but they go all wonky when i turn the headlights on.
Like i said i bought the car with them already wired up and ive never installed aftermarket guages before.. where should i start investigating?
Old Mar 2, 2010 | 11:20 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Re: maybe a ground issue or something?
definitely could be a grounding issue, so I would double check your grounds from the gauges and from your headlights since that seems to be the main culprit, also check to make sure you power wires from your gauges are not contacting the headlight wiring
Frozer!!!
Jan 19, 2024 04:55 PM
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Jae992
Aug 27, 2015 09:07 AM
86Base
Aug 8, 2015 01:34 PM
