msd?
Old Mar 9, 2010 | 07:50 PM
blklblsk8r16's Avatar
msd?
ok so i just installed my msd on my carburated camaro. now all of my lights flash. any ideas?
Old Mar 10, 2010 | 08:41 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Flash Dance
Elaborate.
Flash on and off as if they’re all hooked up to the hazard flasher?
Or are they undulating?
Headlights only or every last light bulb?
Happy Racing!
Make Noise, Turn Left, Repeat
Old Mar 10, 2010 | 08:52 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
Re: Flash Dance
Join the police force? JK. My car has a complete msd system so if you need me to take pics of anything just let me know. I didn't wire it but it works.
Old Mar 10, 2010 | 10:21 AM
Re: msd?
it runs good and everything so im assuming its hooked up right. the lights are plashing... not on and off just dimming they have have a short or something.. maybe a bad ground? should i have grounded the cap out onto the body instead of the block?
Old Mar 10, 2010 | 11:12 AM
NINÅ's Avatar
Transmission: 765R4
Undulation Modulation
If it undulates at low RPM only, the alternator is not putting out a steady voltage, and if the lights are steady when you’re on the loud pedal don’t worry about it.
If it undulates at higher RPM as well, it sounds like you might have temporarily shorted the alternator causing damage to the internal circuitry.
Happy Racing!
How bout those too scared to drive without headlights in the daytime and the ones that need headlights for a little rain
Old Mar 10, 2010 | 11:28 AM
Re: msd?
this is something that i could have done with the vehicle off? i didnt touch any wires with the vehicle running. it does do it at all rpms. it didnt do it until i installed this msd box.
Old Mar 10, 2010 | 02:48 PM
NINÅ's Avatar
Transmission: 765R4
Flash Dance
Because it does it at any RPM I would look at the alternator first.
Take the alternator belt off, if the problem goes away, the alt is bad.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
