Fuel pump suddenly not working??
Old Mar 9, 2010 | 09:38 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Transmission: 700-R4
Axle/Gears: OSD 10 bolt/ 3.42
Ill try to expain the story as best i can...
Ive had my car up on ramps since around lunch time monday and have been working on unbolting my headers to replace the gaskets since they were leaking. I had the spark plug wires and negative battery terminal unpluged while doing this because thats what the book told me to do.
Today i moved some stuff around trying to give myself some more room to work with. I moved a silver metal pipe connected to the circled thing in the picture.
Yesterday before i put the car on ramps, the fuel pump worked great, but now that i have the headers bolted back up, spark plug wires conected, and negative battery terminal connected, the car wont start. It turns over and wants to starts, but i can no longer hear the priming of the fuel pump, where before it used to be very distinctive. I cant seem to find what i may have done to make the pump stop working and was wondering if anybody else has had this problem.
Sorry about the long post, but thiss problem has me worried that i may have done something bad
-Thanks
Old Mar 10, 2010 | 10:36 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Pump Slump
Never had that problem but it sounds like you broke the pump priming circuit.
Check the fusible links, check for broken or pulled wires.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. WLow performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Mar 11, 2010 | 10:38 PM
pbtrilogy's Avatar
Car: 1985 Z
Engine: 89 305 TPI
Re: Fuel pump suddenly not working??
Thats what i was thinking to, but just as it had stopped working, it started working the next day
Old Jul 21, 2012 | 10:49 PM
Keith Yee's Avatar
I changed the fuel filter yesterday and my car will not start up and the fuel pump will not prime. I am confused too. what did you do?
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
